The custom camera option allows users to plan and fly missions with the correct overlap even if the camera is not included in the database of Pix4Dcapture.
In order to create a custom camera, name, focal length, sensor width, image width, and height and the minimum trigger time between pictures need to be defined. It is also possible to edit or delete a custom camera.
The procedure is the following:
1. Open the app.
2. In the Home screen, tap Settings.
3. In the Drone section, tap Camera.
4. In the Custom camera section, tap Add custom camera...
5. Enter Camera name.
6. Enter Focal length [mm].
7. Enter Sensor width [mm].
8. Enter Image width [pixel].
9. Enter Image height [pixel].
10. Enter Min. triggering interval [s].
11. Tap Save to save the camera model.
- According to the selected interval [s], the speed of the drone is adjusted to achieve the desired front overlap [%]. It is not recommended to apply a too small interval as the drone will fly very slowly if the front overlap is high.
- As the triggering is based on time-lapse, pictures accumulate in the corners where the drone slows down to turn.
- Missions flown with a custom camera cannot be synchronized. In other words, images cannot be downloaded from the drone to the device and the project file (.p4d) is not generated. This is, however, not a problem for processing.
