Linux dependencies
Information: A Pix4Dengine license is necessary to install the software on Linux.
Supported OS
  • Ubuntu 14.04
  • Ubuntu 16.04: official support planned for early 2018
Note: Pix4Dmapper version 3.3.14 or onwards is required.
Installation
A PPA for Qt5.6 is required before installing the software.
For Ubuntu 14.04 (Trusty):
sudo add-apt-repository ppa:beineri/opt-qt562-trusty
sudo apt-get update
sudo dpkg -i pix4Dmapper.deb
sudo apt-get install -f
For Ubuntu 16.04 (Xenial, not officially supported):
sudo add-apt-repository ppa:beineri/opt-qt562-xenial
sudo apt-get update
sudo apt install ./pix4dmapper_x.x.x_amd64.deb
Usage
For more information on how to use the command line: 202560329.
For advanced users, more functions can be accessed by modifying the .p4d file: 209829943.
Note: Pix4Dmapper requires the HOME environment variable to be set, and the configuration files (licenses, settings) to be stored at: ~/.config/pix4d. The HOME variable can be checked with the command: echo $HOME in the command line. The ~/ in ~/.config/pix4d refers to the home directory defined by the variable HOME.
3 out of 3 found this helpful
Article feedback
