Output is not displayed / feature is missing in the cloud
The following cases can happen after processing on the cloud.
  • 2D view: The orthomosaic, digital surface model (DSM), or index is not displayed.
  • 3D view: The point cloud or textured mesh is not displayed.
  • The elevation profile does not load.
If the project is uploaded from Pix4D Desktop
A typical cause is related to settings that were selected in Pix4D Desktop beforehand. Pix4D Cloud servers process images based on the project file (.p4d) that is uploaded. Therefore, it can happen that the outputs were not generated nor exported.
It is then required to:
1. Re-open the project with Pix4D Desktop.
2. Change the processing options accordingly as detailed below.
3. Re-upload to Pix4D Cloud for re-processing.
WHAT TO CHECK
HOW TO SOLVE
2D view
GeoTIFF Raster DSM and GeoTIFF Orthomosaic outputs are selected. 1. On the menu bar, click Process > Processing Options...
2. Select the processing step 3. DSM, Orthomosaic and Index.
3. Select the tab DSM and Orthomosaic.
4. Check the two GeoTIFF boxes. The Merge Tiles box does not matter.
For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
GeoTIFF Reflectance and NDVI outputs are selected. 1. On the menu bar, click Process > Processing Options...
3. Select the tab Index Calculator.
4. Check the GeoTIFF box. The Merge Tiles box does not matter.
5. Check the box of the NDVI formula.
For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator.
3D view
LAS Point Cloud output is selected. 1. On the menu bar, click Process > Processing Options...
2. Select the processing step 2. Point Cloud and Mesh.
3. Select the tab Point Cloud.
4. Check the LAS box.
For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
OBJ 3D Textured Mesh output is selected. 1. On the menu bar, click Process > Processing Options...
3. Select the tab 3D Textured Mesh.
4. Check the box Generate 3D Textured Mesh.
5. Check the OBJ box.
For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > 3D Textured Mesh.
General causes
Additional causes can prevent the outputs from being loaded and affect the display.
ISSUE
EXPLANATION
2D and 3D views
Outputs have a significant size and/or a complex geometry.
The cloud viewer can be limited by browser resources (display, memory) because of the input images (number, resolution, content) and project properties (geolocation information, extracted keypoints, resolution settings). For more information: Processing speed.
The web browser application does not support 3D visualization.
It is necessary that the web application supports optimized WebGL for rendering 3D graphics. This is a known issue for some iOS devices. For more information: ArcGIS help, Sketchfab help.
Pix4D Cloud cannot be accessed or some tools are not available in a cloud project
In some cases, an internet browser combined with a specific operating system does not support some or all the functionalities on Pix4D Cloud.
  • The configuration Internet Explorer 11/Windows 10 gives limited access to Pix4D Cloud. Some tools will not be available, like the elevation profile generation.
  • The configuration Internet Explorer 11/Windows 7 is officially not supported.
    For more information about the supported Internet browsers and operating systems for Pix4D Cloud: Cloud general questions.
Project fails to be processed on the servers.
Several leads are recommended to be explored in order to troubleshoot the problem. For more information: Error while processing a project on the cloud .
OBJ 3D Textured Mesh exceeds 1 GB
Pix4D Cloud supports visualizing OBJ 3D Textured Meshes that are smaller than 1 GB. Please ensure that your OBJ 3D Textured Mesh is smaller than 1 GB before uploading it to Pix4D Cloud.
Elevation profile / cross-section is missing
One of these might be the reason:
  • The project results can be shared using the Share button in the upper-right corner. All the content of the 2D or 3D view together with the annotations are shared except the elevation profile / cross-section, which has to be re-triggered everytime.
  • If the 3D Mesh is uploaded as a result, it is not georeferenced. The elevation profile generated on this output, will not be available.
  • Once the project has been uploaded for processing or the results uploaded to the cloud and one output is replaced with a new one with a different coordinate system than the project's one, the elevation profile is not available if generated on that replaced output.
Error calculating the volume
The occurrence of one of the following conditions prevents the volumes from being calculated:
  • No DSM is available
  • The 3D mesh is uploaded from the cloud interface and the volume is calculated on the 3D mesh (the base surfaces that are being drawn on the mesh do not intersect any valid region of the DSM)
  • The coordinate system used is not one of those recognized as valid
  • The coordinate system is arbitrary
2D view
Images are captured with a multi-spectral camera.
One GeoTIFF file is generated per band instead of the single true color orthomosaic. The cloud platform only displays the DSM and NDVI outputs. However, all GeoTIFF files are downloadable. For more information: How to download results from the cloud.
0 out of 3 found this helpful
