Output is not displayed / feature is missing on Pix4Dcloud
The following cases can happen after creating a project on Pix4Dcloud.
  • 2D view: The orthomosaic / DSM / Index map is not displayed.
  • 3D view: The Point Cloud / 3D Textured Mesh is not displayed.
  • The elevation profile does not load.
  • The volume cannot be calculated.
If the project was uploaded from Pix4Dmapper
Here a list of possible issues.
Note: A typical cause of missing outputs is related to the Processing Options that were selected in Pix4Dmapper before uploading, which are saved in the .p4d file. Pix4Dcloud servers process images based on the project file (.p4d) that is uploaded. Therefore, it can happen that the outputs were not selected as exports or the processing steps that generate the desired outputs were not marked to be run.
Error description
Cause / How to solve
The DSM and/or Orthomosaic are not displayed in the 2D view. In the Files > Results section the DSM and/or Orthomosaic show the EMPTY status.
The correct output format was not selected before uploading.
1. In Pix4Dmapper, re-open the project. On the menu bar, click Process > Processing Options...
2. Select the processing step 3. DSM, Orthomosaic and Index.
3. Mark the checkbox corresponding to Step 3. DSM, Orthomosaic and Index.
4. Select the tab DSM and Orthomosaic.
5. Check the GeoTIFF box for the desired output. The Merge Tiles box does not matter.
For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
6. Re-upload the project to Pix4Dcloud.
The DSM and/or Orthomosaic are not displayed in the 2D view. The Orthomosaic layer has a warning message "This layer can't be displayed". In the Files > Results section, the DSM and/or Orthomosaic show the PROCESSED status. They can be considered having a significant size and/or a complex geometry.
This error is expected for outputs having a significant size and/or a complex geometry. In this case, the tiling process failed, meaning that the generated 2D output could not be split into smaller web maps (tiles) for several zoom levels and, for this reason, the output cannot be displayed. The output has been generated and indeed it can be downloaded from the Results page, but the file is too big to be displayed on the 2D view of Pix4Dcloud.
So far, these are the variables that seem to be impacting the tile generation speed:
  • The significant size of the file (large surface and/or high resolution, a large number of points).
  • The complex geographic transformation from the project coordinate system to WGS84 that is used on web maps.
  • Corridor projects.
  • The multiple-blocks project, with not homogeneous tiles.
Some proposed solutions:
  • The resolution of the output file can be reduced.
  • The file can be split into multiple parts with some third-party software and then uploaded again in different separate projects on Pix4Dcloud.
  • The file can be replaced with a smaller one.
  • A processing area can be defined in Pix4Dmapper before uploading the project to Pix4Dcloud for processing.
There is no precise file dimension that prevents the failure of the tiling process as this depends on different factors among which the number of the images, the image content and texture, the complexity of the geometry of the model, the geographic transformations, etc..
The NDVI is not displayed in the 2D view. In the Files > Results section the NDVI shows the EMPTY status.
4. Select the tab Index Calculator.
5. Under Reflectance Map, check the GeoTIFF box to generate the Reflectance Maps. The Merge Tiles box does not matter.
6. Check the box of the NDVI formula to generate the NDVI Index Map.
For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator.
7. Re-upload the project to Pix4Dcloud.
The Point Cloud is not displayed in the 3D view. In the Files > Results section the Point Cloud shows the EMPTY status.
2. Select the processing step 2. Point Cloud and Mesh.
3. Mark the checkbox corresponding to Step 2. Point Cloud and Mesh.
4. Select the tab Point Cloud.
5. Check the LAS box.
For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
The 3D Textured Mesh is not displayed in the 3D view. In the Files > Results section the Mesh OBJ shows the EMPTY status.
4. Select the tab 3D Textured Mesh.
5. Check the box Generate 3D Textured Mesh.
6. Check the OBJ box.
For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > 3D Textured Mesh.
If the project was created and processed on Pix4Dcloud
Some common errors are listed here.
Error description
The DSM and/or Orthomosaic are not displayed in the 2D view. The Orthomosaic layer has a warning message "This layer can't be displayed". In the Files > Results section the DSM and/or Orthomosaic show the PROCESSED status. They can be considered having a significant size and/or a complex geometry.
If some results were uploaded or replaced on Pix4Dcloud
Error description
The Point Cloud and 3D Textured Mesh are uploaded as results and the 3D view has visualization issues.
The issue is due to the merged viewer/editor that displays the non-georeferenced 3D Mesh and the georeferenced Point Cloud together. The mesh (.obj, .jpg and .mtl) uploaded as a result to the Cloud is indeed not georeferenced. However, there is an option for georeferencing the uploaded mesh:
1. In the project, go to Files > Results.
2. In the Mesh OBJ section, click Replace Files.
3. Browse the project_name_offset.xyz file that can be found in the ..\1_initial\params folder. Select the file and click Open.
4. Drag and drop the files of the mesh (.obj, .jpg and .mtl) into the uploader.
Alternatively, copy the project_name_offset.xyz file into the folder ..\2_densification\3d_mesh, then drag and drop the four .obj, .jpg, .mtl and .xyz files into the Mesh OBJ section.
The Point Cloud is partially displayed. Multiple LAS tile files were generated locally and uploaded.
Only one LAS file can be uploaded as a result to Pix4Dcloud.
What is happening is that Pix4Dcloud is only able to load one file at a time, so it's choosing to display one tile only.
Check How to merge the Tiles of the Point Cloud to merge the tiles that were created in Pix4Dmapper and then upload the merged LAS file or use some third-party software to merge the tiles.
The 3D view doesn't render the Mesh file and the OBJ 3D Textured Mesh exceeds 1 GB.
Pix4Dcloud supports visualizing OBJ Mesh files that are smaller than 1 GB. Ensure that the OBJ 3D Textured Mesh is smaller than 1 GB before uploading it to Pix4Dcloud.
The 3D view doesn't render the Mesh file and the JPG Texture file exceeds 16384 x 16384 pixels.
Pix4Dcloud supports 3D Textured Mesh files having a JPG texture image that is at maximum 16384 x 16384 pixels. Please ensure that your JPG Texture file is smaller than this size before uploading it to Pix4Dcloud.
Other general errors
Error description
The project status is UPLOADED, the UI contains no layers.
The project files were uploaded from Pix4Dmapper without selecting Start processing. Then, from the Files > Results section the results were uploaded.
In this way Pix4Dcloud receives both the images and the p4d file for the (photogrammetric) processing but also the results that need to be web-optimized to be displayed. The result of this workflow is that the status of the project is stuck because the app is not able to decide whether it should start processing the images or the results.
If the goal is to upload the results without any processing, the p4d file and the images are of no use and shouldn't be uploaded to Pix4Dcloud.
Upload the results creating a new dataset, as explained here.
The 3D view doesn't render.
It is necessary that the web browser application supports optimized WebGL for rendering 3D graphics. This is a known issue for some iOS devices. For more information: ArcGIS help, Sketchfab help.
Pix4Dcloud cannot be accessed or some tools are not available in a Pix4Dcloud project
First of all, ensure your browser is up-to-date. For more information about the supported Internet browsers and operating systems for Pix4Dcloud: Pix4Dcloud - FAQ.
In some cases, an internet browser combined with a specific operating system does not support some or all the functionalities on Pix4Dcloud.
  • The configuration Internet Explorer 11/Windows 10 gives limited access to Pix4Dcloud. Some tools will not be available, as the elevation profile generation.
  • The configuration Internet Explorer 11/Windows 7 is officially not supported.
The elevation profile is missing
One of these might be the reason:
  • No DSM is available.
  • The project results can be shared using the Share button in the upper-right corner. All the content of the 2D or 3D view together with the annotations are shared except the elevation profile, which has to be re-triggered every time.
  • If the 3D Mesh is uploaded as a result without the offset file, it is not georeferenced. The elevation profile generated on this output, will not be available.
  • Once the project has been uploaded for processing or the results uploaded to Pix4Dcloud and one output is replaced with a new one with a different coordinate system than the project's one, the elevation profile is not available if generated on that replaced output.
Error calculating the volume
The occurrence of one of the following conditions prevents the volumes from being calculated:
  • The 3D mesh is uploaded from the Cloud interface and the volume is calculated on the 3D mesh (the base surfaces that are being drawn on the mesh do not intersect any valid region of the DSM)
  • The coordinate system used is not one of those recognized as valid
  • The coordinate system is arbitrary
Images are captured with a multi-spectral camera.
One GeoTIFF file is generated per band instead of the single true color orthomosaic. The Cloud platform only displays the DSM and NDVI outputs. However, all GeoTIFF files are downloadable. For more information: How to download results from the cloud.
The project is in the ERROR status.
The project has failed to be processed on the servers. Different leads are recommended to be explored in order to troubleshoot the problem. For more information: Error while processing a project on Pix4Dcloud.
1 out of 8 found this helpful
