Pix4Dmapper Getting Started PDF version - EN, ES, FR, PT, LV, UA, RU
The Getting Started guides are available in PDF version below:
Pix4Dmapper
Getting Started - English
Guía de iniciación - Spanish
Guide de démarrage - French
Guia para iniciantes - Portuguese
Jaunajiem lietotājiem - Latvian
Посібник з початку роботи - Ukrainian
Руководство по началу работы - Russian
5 out of 5 found this helpful
3 comments
  • Alvaro Torres
    hola Rut:
    Estoy presentando un proyecto de agricultura de precisión; por lo tanto requiero que me ayudes con datasheet de fix4d mapper y fix4d fields; ya que necesito argumentar el software que voy a utilizar para el procesamiento de imágenes.
    Saludos
  • Deschamps Olivier
    Hi,
    how I set a 45° angle on a circular plane
    and on a second flight at 35 degrees,I decrease manually
    Thank you olivier
  • Avatar
    Blaž (Pix4D)
    Hi Olivier,
    When flying circular missions in Pix4Dcapture, the camera angle is automatically set so that it points toward the center of the mission and to the ground. It is not possible to manually define the angle of the camera in circular missions.
    More in the Pix4Dcapture - Manual and Settings article.
    Best,
