(iOS) Free Flight Mission Settings
Manual
Settings
General
Polygon
Grid
Double Grid
Circular
Free Flight
Access: In the Home screen, select Free Flight. In the Map view, tap ic_settings_green.png.
OPTION DESCRIPTION
White balance
Defines the white balance to apply between Auto (default), Sunny and Cloudy.
Information: It allows to compensate temperatures so that the color of the image is as close as possible to neutral which corresponds to sunlight at noon outdoor. For each image the temperature is adjusted by an algorithm that optimizes the colors.
The Reset all settings button makes all options revert to their default values.
0 out of 2 found this helpful
