Circular Mission Settings (iOS) - PIX4Dcapture
Drone speed
Defines the drone's speed from a range between Slow and Fast (default). The maximum speed depends on the selected overlap and flight altitude. The scale has five levels corresponding to percentages of the maximum speed between 100% (Fast) and 60% (Slow). The speed should fluctuate between 2 and 8 m/s for copters and is not constant during the flight since the drone slows down to trigger pictures.
Angle between images (°)
Defines the angle that separates consecutive images. The smaller the angle, the higher the image overlap. The value varies between 4° (Low) and 20° (High). The default value is 10° but if it was changed previously, the angle is the one of the last planned mission.
Picture trigger mode
- Except DJI drones
Defines how pictures are triggered between stopping to shoot, Safe mode, or while the drone is flying, Fast mode (default).
White balance
Advanced
- Except Bebop 2
Defines the white balance to apply between Auto (default), Sunny and Cloudy.
Ignore homepoint
Advanced
Defines whether the maximum authorized distance (2 km) between the home point and the flight plan is applied, No (default), or ignored, Yes, to start the mission.
The Reset all settings button makes all options revert to their default values.
