Processing Options Templates
 Previous  |  Next
These are the default Processing Options Templates available in Pix4Dag. We strongly recommend using these to process your projects.
Processing Options Template Description
Ag Multispectral Outputs: reflectance, index (such as NDVI), classification and application maps.
Typical input: aerial nadir images from multispectral cameras (Sequoia, Micasense RedEdge, Multispec 4C, etc).
Outputs quality/reliability: high.
Processing speed: slow.
Application: precision agriculture.
Ag Modified Camera Outputs: reflectance, index (such as NDVI), classification and application maps.
Typical input: aerial nadir images from modified RGB cameras.
Ag RGB Output: orthomosaic.
Typical input: images from RGB cameras for agriculture (Sequoia RGB).
Processing speed: average.
Application: digital scouting, report claiming for precision agriculture.
Ag Modified Camera - Rapid/Low Res Faster processing of the Ag Modified Camera  template for assessing the quality of the acquired dataset.
Outputs quality/reliability: low.
Processing speed: fast.
Ag RGB - Rapid/Low Res Faster processing of the Ag RGB template for assessing the quality of the acquired dataset.
Thermal Camera Output: thermal reflectance map.
Typical input: thermal cameras (Tau 2 based: FLIR Vue Pro, FLIR XT).
Application: irrigation control, solar panels, building inspection, etc.
ThermoMAP Camera Output:  thermal reflectance map.
Typical input: nadir images taken with thermoMAP camera.
Output quality/reliability: high.
0 out of 0 found this helpful
