License activation
 Previous  |  Next
If the license is not already assigned to your account via an e-commerce purchase. The license redeem makes sure that you are the owner of your license. First, make sure that you have a Pix4D account. If not, create a Pix4D account as described in section Sign-up. The steps to redeem the license are:
  1. Click the link under Activation Instructions in the License Certificate you have received when purchasing the Pix4D license. Or go to: https://cloud.pix4d.com/license-redeem/
  2. Enter the license key in the box below:
  3. Click Redeem and the license is under your account.
Note: To redeem a voucher bundled with a Sequoia camera, access the link at the bottom of the coupon you have received and the same procedure as above applies.
1 out of 2 found this helpful
