License activation
 Previous  |  Next
If the license is not already assigned to your account via an e-commerce purchase. The license redeem makes sure that you are the owner of your license. First, make sure that you have a Pix4D account. If not, create a Pix4D account as described in section Sign-up. The steps to redeem the license are:
  1. Click the link under Activation Instructions in the License Certificate you have received when purchasing the Pix4D license. Or go to: https://cloud.pix4d.com/license-redeem/
  2. Enter the license key in the box below:
  3. Click Redeem and the license is under your account.
Note: To redeem a voucher bundled with a Sequoia camera, access the link at the bottom of the coupon you have received and the same procedure as above applies.
1 out of 5 found this helpful
3 comments
  • Luís Reia
    Hello. I've bougth a license, it is in the cloud, but is continuing to saying there isn't any valid license. What do i have to do? I've a lot of projets, that i need to work with.... HELP...
  • Luís Reia
  • Kapil (Pix4D)
    Hi Luis,
    I see your license was activated successfully. If the problem was not solved you can directly write to us by using the "contact support" option available at the top of the page.
