Previous | Next |
These are the default Processing Options Templates available in Pix4Dmapper. We strongly recommend using these to process your projects:
Processing Options Template | Description |
3D Maps |
Outputs: 3D map (point cloud, 3D textured mesh) as well as a DSM and an Orthomosaic. Typical input: aerial images acquired using a grid flight plan. Outputs quality/reliability: high. Processing speed: slow. Applications: quarries, cadaster, etc. |
3D Models |
Outputs: 3D model (point cloud, 3D texture mesh). Typical input: aerial oblique or terrestrial images with high overlap. Outputs quality/reliability: high. Processing speed: slow. |
Ag Multispectral |
Outputs: reflectance, index (such as NDVI), classification and application maps. Typical input: aerial nadir images from multispectral cameras (Sequoia, Micasense RedEdge, Multispec 4C, etc). Outputs quality/reliability: high. Processing speed: slow. Application: precision agriculture. |
Ag Modified Camera |
Outputs: reflectance, index (such as NDVI), classification and application maps. Typical input: aerial nadir images from modified RGB cameras. Outputs quality/reliability: high. Processing speed: slow. Application: precision agriculture. |
Ag RGB |
Output: orthomosaic. Typical input: images from RGB cameras for agriculture (Sequoia RGB). Outputs quality/reliability: high. Processing speed: average. Application: digital scouting, report claiming for precision agriculture. |
3D Maps - Rapid/Low Res |
Faster processing of the 3D Maps template for assessing the quality of the acquired dataset. Outputs quality/reliability: low. Processing speed: fast. |
3D Models - Rapid/Low Res |
Faster processing of the 3D Models template for assessing the quality of the acquired dataset. Outputs quality/reliability: low. Processing speed: fast. |
Ag Modified Camera - Rapid/Low Res |
Faster processing of the Ag Modified Camera template for assessing the quality of the acquired dataset. Outputs quality/reliability: low. Processing speed: fast. |
Ag RGB - Rapid/Low Res |
Faster processing of the Ag RGB template for assessing the quality of the acquired dataset. Outputs quality/reliability: low. Processing speed: fast. |
Thermal Camera |
Output: thermal reflectance map. Typical input: thermal cameras (Tau 2 based: FLIR Vue Pro, FLIR XT). Outputs quality/reliability: high. Processing speed: slow. Application: irrigation control, solar panels, building inspection, etc. |
ThermoMAP Camera |
Output: thermal reflectance map. Typical input: nadir images taken with thermoMAP camera. Output quality/reliability: high. Processing speed: slow. |
