Inputs and outputs
 Previous  |  Next
Inputs
The main input to Pix4Dmodel are images that can be either JPEG or TIFF files. Video files can also be imported and used for processing (instead of still images).
Warning: Do not modify the images, i.e. do not rotate or edit the images. Modifying images alters the geometrical properties of the camera and may deteriorate the quality of the results.
Extension Description
.jpg, .jpeg JPEG images
.tif, .tiff Monochromatic TIFF
Multi-band TIFF (RGB / Infrared / thermal)
1 layer (no pyramid, no multi-page)
8, 10, 12, 14, 16 bit integer, floating point
.avi, .mp4, .wmv, .mov Video files that can be imported into Pix4Dmodel
Outputs
Pix4Dmodel can generate these outputs:
  • 3D textured mesh (.obj, .fbx, .dxf, .ply, .pdf, .osgb, .slpk): This is a representation of the shape of the model that consists of vertices, edges, faces and the texture from the images that is projected on it.
  • Video animation (.mp4, .mkv, .avi)
4 out of 4 found this helpful
2 comments
