Previous | Next |
Download
Installation
Language settings
Update
License deactivation
At any given time there are two versions available to download:
- Pix4D Desktop: This version is meant for production work.
- Pix4D Desktop Preview: This version contains the newest features, but is not meant for production work.
Download
To download the software:
- Go to the download page.
- Download Pix4D Desktop or Pix4D Desktop Preview.
Installation
Once the software has been downloaded, install it using the following steps:
1. Double-click the downloaded file. The Pix4Dmapper Setup wizard starts.
2. (optional) If the pop-up Open file - Security Warning appears, click Run.
3. In the pop-up Pix4Dmapper Setup, in the screen Welcome to the Pix4Dmapper Setup Wizard, click Next.
4. (optional) Click Change... to change the destination path for the installation and click Next.
5. Click Install.
6. (optional) In the software information window: "Do you want to allow this app to make changes to your device?", click Yes.
7. Click Finish.
8. A shortcut is created on your desktop and the software opens automatically once the installation is completed.
9. The first time the software opens, the window Pix4Ddesktop Login appears:
10. Type the Email and Password of the account and click Login.
11. Read the End-User License Agreement, select I accept the terms in the License Agreement and click Next.
12. Select one of these options:
12.1 Request Pix4Dmapper now (free trial) to activate a 15-day trial.
12.2 Use Pix4Ddiscovery to activate the limited version.
12.3 Available licenses to select among existing licenses on the account.
13. Click OK.
Pix4D Desktop is now ready for processing.
Language settings
You can change the language settings on Pix4D Desktop at anytime:
1. Start Pix4D Desktop.
2. On the menu bar, click Help > Settings…
3. In the window Settings, select the tab Language.
4. Select the user interface language from the drop-down list.
5. Click OK.
The changes will take effect when the software is restarted.
Update
The most recent Pix4D Desktop and Pix4D Desktop Preview versions are always available for download. Additionally, if a new version of Pix4D Desktop is available, a pop-up Software Update with three options is displayed when the software is opened:
- Download and Install Now to download and install the latest version available.
- Remind Me Later to not download or install the latest version. The pop-up will appear again in 10 days.
- Cancel to not download or install the latest version. No reminder will appear.
Starting from the 4.0 version, a new license management has been implemented, enabling to remotely deactivate a device:
1. Log out of Pix4D Desktop.
2. Go to the License Management panel.
3. Under the license, click Enable now.
4. Log in Pix4D Desktop. This will automatically register the device on the License page.
5. To deactivate the device, go to the License Management panel and next to thedevice name click Deactivate.
pix4d software
Hi, i have a perpetual license of pix4d desktop, my problem is that the last device user is broken, and it looks like I´m not able to deactivate it. I would like to know if you can support me to fix it, My user account is uise.nuevoleon.gob.mx and the device name that is causing me troubles is LAPTOP-CTEQARN5.
Thank you
Hi,
I deactivated your device as requested.
Best regards! ;-)
Hello
Is there a mechanism to prevent the check and prompting of updates for a lab environment? We don't want the users seeing the upgrade prompt and trying to perform the update.
Thanks
Hi Mohammad,
Unfortunately, it is not possible; I'll take it as a note and pass it to our teams as a feature request.
Kind regards,
Hola, cuales son los requerimientos para uso en OSX? que osx minimo requiere?
Hola, Pix4mapper ya no se desarrolla en una version macOS. Tenemos una version de Pix4Dmapper que funciona en macOS (Pix4Dmapper 3) que es bastente antigua y no se soporta oficilamente pero tenemos usuarios que la utllizen. Aqui puedes encontrar toda la informacion: Beta macOS version of Pix4Dmapper 3.0
Hi
Like Sedagro NL I have a perpetual license I lost the hard drive on the one device and I cannot deactivate it the Device 11471-PC. I have another device but it cannot log into Pix4d due a server communications error to the so I cannot use it or deactivate it either. Device 10417-PC Can I get them deactivated so I can get another machine working on our project. Thank you
Hello, I have deactivated the license from both machines. You should be able to use them now. Let us know if you get any issues.
Thank you very much have a great day !
Hello!
I tried to process images from a MicaSense camera with the AgMultispectral function to assemble the orthomosaic, but it throws the following error:
[Warning]: Warning w9020: GDAL Error <4> Unable to create jpeg file C:/Users/VISTAGUAY/Documents/pix4d/LosC/1_initial/project_data/normalised/IMG_0000_1.jpg.
[Error]: Failed to write to <C:/Users/VISTAGUAY/Documents/pix4d/LosC/1_initial/project_data/normalised/IMG_0000_1.jpg
Hi Nicolas, Can you send the logfile?
Hola, trato de instalar pix4d mapper en mi nueva pc porque la anterior se daño, pero no puedo desactivar el equipo anterior. podrían ayudarme?
Hola Julio. Ya la he desactivado. Ahora la puedes activar de nuevo.
