Camera radiometric correction specifications
To be able to perform the camera radiometric corrections (Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator), the Pix4D software requires at a minimum the following tags:
  • Exif.Photo.ExposureTime
  • Exif.Photo.FNumber
  • Exif.Photo.ISOSpeedRatings
Vignetting
The information for the vignetting correction can be provided either as a 2D polynomial or as a radial polynomial.
Radial polynomial
The polynomial is of the form:
 equation.svg
with (Cx, Cy) read from Xmp.Camera.VignettingCenter and the coefficients ci read from Xmp.Camera.VignettingPolynomial.
2D polynomial
equation__1_.svg
The tag Xmp.Camera.VignettingPolynomial2DName contains the i and j values of c{i,j} and the value of c{i,j} is stored in Xmp.Camera.VignettingPolynomial2D. For example, Xmp.Camera.VignettingPolynomial2DName={"0,0,1,0, ..., 2,2,3,1"} and Xmp.Camera.VignettingPolynomial2D={0.633287676149, 1.47936368033, ..., -1.58329242609, 0.130259802058} means c_{0,0}=0.633287676149, c_{1,0}=1.47936368033, etc...
Dark current
Xmp.Camera.BlackCurrent indicates the dark current. There is one value per band, and the dark current is assumed uniform for all pixels on this band.
It is also possible to use the standard tags Exif.Image.BlackLevel and Exif.Image.BlackLevelRepeatDim.
Normalized images
If the image was already radiometrically corrected and contains absolute irradiance or temperature, the following tag should be set to 1:
  • Xmp.Camera.IsNormalized
4 out of 5 found this helpful
