OPTION | DESCRIPTION |
General | |
Drone |
Selects the drone to fly. For more information: (Android, iOS) Which drones are supported by Pix4Dcapture. |
Units |
Selects between Metric or Imperial. The default selection depends on the geolocation of the device. |
Sync automatically |
Defines whether the mission is synchronized right after the flight, Checked (default), or manually by the user later, Unchecked. For more information: Synchronization and Upload / How to synchronize and upload a mission to the Pix4D Cloud. |
Enable audio feedback |
Defines whether the app emits signal tones, Checked, or is muted, Unchecked. Sounds are emitted when pictures are triggered, when the battery level drops down below 20%, etc. |
About |
Opens a sub-menu with information about the Privacy policy (Pix4D main site) and App version. |
Maps | |
Save offline maps |
Defines whether the base map is exported and save on the device when planning a mission, Checked (default), or not, Unchecked. For more information: Offline basemap and missions / How to operate flights without internet. |
Street base map provider |
Opens a pop-up to select and manage alternative providers for the street base map. Default is Mapbox / OpenStreetMap. For more information: Offline basemap and missions / How to operate flights without internet. |
Satellite base map provider |
Opens a pop-up to select and manage alternative providers for the satellite base map. Default is Mapbox. For more information: Offline basemap and missions / How to operate flights without internet. |
Advanced | |
Defines whether the advanced user mode is activated to plan and fly, Checked, or not, Unchecked. This mode allows more flexibility with the mission settings like flying higher than 150 m above ground level and to start a mission even if the home point is further than 150 m away from the flight. For more information: (Android, iOS) What is maximum distance to the flight?. |
Root directory path |
Defines the folder on the device (internal memory or SD card) where to store the app and mission files. The default path is /storage/emulated/0/Pix4D. This can be changed if needed (path is case sensitive). |
it is very frustrating to know that my cellphone with android 6 is no more supported for last version of pix4D Capture
