(Android) Pix4Dcapture Release 3.8
Download Pix4Dcapture for Android via Google Play (click below for direct access):
3.8.1 April 24, 2017 New, bug fix
3.8.0 April 6, 2017 New
Compatible drones
  • DJI Inspire 1 and Inspire 1 Pro (I1).
  • DJI Inspire 2 (I2).
  • DJI Mavic Pro (MP).
  • DJI Matrice 100 (M100).
  • DJI Phantom 2 Vision (P2V).
  • DJI Phantom 2 Vision+ (P2V+).
  • DJI Phantom 3 Advanced (P3A).
  • DJI Phantom 3 Professional (P3P).
  • DJI Phantom 3 Standard (P3S).
  • DJI Phantom 4 (P4).
  • DJI Phantom 4 Pro (P4P).
  • Parrot Bebop 2 (B2).
  • 3DR Solo (Solo): beta.
For more information about supported hardware: 203991609.
Important
If using a DJI drone (except P2V, P2V+) download the plugin app Ctrl+DJI:
If using a Parrot drone, download the plugin app Ctrl+Parrot:
Notes
  • (3DR Solo) Beta support of with GoPro Hero 4 (Black or Silver) only.
Version 3.8.1
What is new
  • Support of DJI Inspire 2: only the X4S was tested but the drone is also expected to fly with the X5S camera.
Important: For the grid and double grid missions, the overlap is computed based on the camera properties of X4S. It is suggested to add 5% to the desired image overlap when using X5S. For instance, the targeted overlap is 70%, apply 75% instead in the flight settings.
Bug fixes
  • Various bug fixes.
Known issues
  • (Inspire 1 with X5, Matrice 100 with X5, Mavic Pro) The mission cannot be synchronized even manually. For more information: 204716225. In this case, processing without the .p4d file is recommended. For more information: 204911905.
  • (Mavic Pro) The Map view does not display the picture icons during the mission even if the images are correctly captured.
Version 3.8.0
What is new
Missions
  • (Bebop 2) Support of Skycontroller 2.
Improvements
Missions
  • (Bebop 2) Drone does not stop when taking pictures.
Bug fixes
  • Fix several UI related bugs.
Known issues
  • (Inspire 1 with X5, Matrice 100 with X5) The mission cannot be synchronized even manually. For more information: 204716225. In this case, processing without the .p4d file is recommended. For more information: 204911905.
0 out of 0 found this helpful
Powered by Zendesk
