(iOS) Pix4Dcapture Release 1.7
Download Pix4Dcapture for iOS via the App Store (click below for direct access):
1.7.1 April 24, 2017 New, bug fix
1.7.0 March 23, 2017 New, bug fix
Compatible drones
  • DJI Inspire 1 and Inspire 1 Pro (I1).
  • DJI Inspire 2 (I2).
  • DJI Mavic Pro (MP).
  • DJI Matrice 100 (M100).
  • DJI Phantom 3 Advanced (P3A).
  • DJI Phantom 3 Professional (P3P).
  • DJI Phantom 3 Standard (P3S).
  • DJI Phantom 4 (P4).
  • DJI Phantom 4 Pro (P4P).
  • Parrot Bebop 2 (B2).
For more information about supported hardware: 203991609.
Important
This version does not support DJI Phantom 2 Vision and DJI Phantom 2 Vision+ drones.
Please download the app called Pix4Dcapture P2V(+): 205708215.
Notes
  • No free flight mission available for Bebop 2.
Version 1.7.1
What is new
  • Support of DJI Inspire 2: only the X4S was tested but the drone is also expected to fly with the X5S camera.
Bug fixes
  • Fix UI bugs for iPhone 5C.
  • Various bug fixes.
Known issues
  • (Inspire 1 with X5, Matrice 100 with X5, Mavic Pro) The mission cannot be synchronized even manually. For more information: 204057579. In this case, processing without the .p4d file is recommended. For more information: 204911905.
  • (DJI drones) Cannot start mission if pilot mode switch is changed during takeoff checklist. As a workaround, tap Cancel and restart the mission.
  • (Phantom 4 Pro) The names of the images on the SD card does not correspond to the names on the device and in the .p4d file. It is recommended when using the .p4d file to use the images from the device.
Version 1.7.0
What is new
Missions
  • (DJI drones, Bebop 2) Polygon mission. For more information: 115001482703.
  • (Bebop 2) Fast mode available for all missions.
  • Visual distinction between connection lines (dashed) and lines where images are captured (full) for polygon and simple grid missions.
General
  • Tutorial with instructions on how to design a polygon mission.
Improvements
General
  • Improved general settings menu layout.
Bug fixes
  • Fix several UI related bugs.
Known issues
  • (Inspire 1 with X5, Matrice 100 with X5) The mission cannot be synchronized even manually. For more information: 204057579. In this case, processing without the .p4d file is recommended. For more information: 204911905.
Powered by Zendesk
