What is maximum distance to the flight? - PIX4Dcapture
There are two safety locks relying on the distance to the flight. They prevent the drone from starting the mission:
  • Between the center of the flight and the home point. The maximum distance is 150 meters.
  • Between the center of the flight and the current position of the drone. The maximum distance is 250 meters.
Distance between the center of the flight and the home point
The home point is actually where the drone is turned on and acquired the GPS signal the first time. This distance is mainly for security reasons, to prevent an accidental launch of a mission when the grid is too far away and it is also limited to prevent connectivity losses.
The limitation can be bypassed if needed:
Android
  1. In the Home screen, tap Settings.
  2. In the Settings menu, go to the section Advanced.
  3. Check the box Enable advanced mode.
iOS
  1. In the Home screen, select a type of mission.
  2. On the toolbar of the Map view, tap the settings icon.
  3. Select the Advanced settings menu.
  4. For the option Ignore home point, select Yes.
Distance between the center of the flight and the current position of the drone
The current position is either on the ground or in the air hovering (e.g. the drone starts a second mission right after the first without coming back to the user). Like for the distance to the home point, this is a safety lock.
The limitation can be bypassed if needed: The pilot has to take off manually and fly the drone closer to the flight before tapping the green button to initiate the mission (in the takeoff checklist).
6 out of 8 found this helpful
4 comments
  • Fabio Marco
    Il drone phantom4 acquisisce la missione tutti i check sono ok ma non decolla non accende i motori e dopo qualche secondo esce la scritta " internal Dji error" .
    Le modalità avanzate sono abilitate
    Il mio tablet é un Asus S3 64gb android 7
    Lo stesso drone usando Ios funziona perfettamente.
    Grazie per un aiuto
  • Avatar
    Gaël (Pix4D)
    Ciao Fabio,
    Hai accesso a Internet quando provi a volare?
    Ti suggerirei di controllare che tu non stia cercando di volare in una DJI No-Fly-Zone.
    Inoltre, questo problema sembra presentarsi quando i parametri fissati in DJI GO 4 sono in conflitto con la missione che stai provando ad eseguire.
    Ti consiglio di controllare in DJI GO 4 che:
    - Il beginner Mode sia disattivato
    - Set Max Altitude sia impostato su un valore non inferiore a quello impostato in Pix4Dcapture. Il valore può essere impostato a zero per essere sicuri di non sbagliare.
    - Enable Max Distance sia disattivato.
    - Gli altri parametri non siano in conflitto con le impostazioni della missione in Pix4Dcapture.
    Se il problema persiste, prova il nostro troubleshooter: ti consentirà di risolvere la maggior parte dei tuoi problemi in pochi minuti!
    Se desideri interagire o condividere il tuo feedback sulla nostra Community, puoi creare un nuovo thread in questo post già esistente su un argomento simile.
  • Dener Rover
    Tenho uma dúvida. Caso o drone perder o sinal ele retornará imediatamente ao ponto de partida ou terminará a missão para depois retornar?
  • Yuka (Pix4D)
    Hello,
    The drone would normally continue the mission; however, it also depends on how you have configured their drone. In DJI Go, If you have configured their drone to RTH on signal loss, then that might happen. As a rule, autonomous missions will run to completion regardless of signal loss.
    Warm regards,
    Edited by Yuka (Pix4D)
