Impossible to enter the Period Symbol "." in Pix4Dmapper
With the release of version 3.1 of Pix4Dmapper, a Windows setting that was previously ignored is now taken into account. This leads to the period symbol not being accepted when using it in Pix4Dmapper.
To solve the problem, the system default settings for numbers should be reset. This can be done following these steps:
  1. Open the Windows Control Panel.
  2. Click Change date, time or number formats under the section Clock, Language and Region.
  3. In the Region pop-up, select the Formats tab and click Additional settings...
  4. In the Customize Format pop-up, select the Numbers tab and click Reset.
Tip: If the Reset option does not work, try to change the Decimal symbol in the Customize Format pop-up to ".".
0 out of 0 found this helpful
