Technical release notes (Android/APK) - PIX4Dcapture Pro
Download the latest APK version.
Android
Current Versions 1.2.0
1.2.0 Sep 26th, 2023 Major release
What's new:
  • New DJI drones support: DJI Mini 3 Pro, DJI Mini 3, and DJI Mavic 3M.
  • Corridor Mission.
  • New PIX4D licensing system.
  • Parrot GSDK 7.7.0.
  • Bug fixes and improvements.
Versions 1.1.0
1.1.0 July 26th, 2023 Bug fixes, Improvements
What's new:
  • Update DJI SDK 5.5.0.
  • Search widget in the map.
  • Anafi USA MIL support.
  • Fixed crash when computing mission.
  • Mission summary.
  • Live feed widget improvements.
  • Telemetry for TA.
  • Support for multiple live feed drones.
  • GSD calculation fixed.
  • TA chart improvements.
  • Sorting feature for mission and projects.
  • Auto highlight and scroll for selected mission.
  • Display grid area and circular missions radius.
  • Disable image watermark.
  • Fixed RTK connection popup not being displayed.
  • Increased offline maps download region.
  • User interface improvements.
  • App stability improvements.
Known issue:
  • DJI M300RTK, M3E & M3T drone models not taking-off due to a remote ID error in the USA.
Versions 1.0.3
1.0.3 July 3rd, 2023 Bug fixes, Improvements
Bug fixes and Improvements:
  • Update Android Parrot Ground SDK 7.6.0.
  • Update Android DJI SDK 5.4.0
Versions 1.0.2
1.0.2 June 22nd, 2023 Bug fixes, Improvements
  • Fixed Parrot Anafi 4K/Thermal/USA overshooting the first waypoint in Grid Mission.
  • Fixed Parrot Anafi USA camera model sometimes not recognized at the mission checklist.
  • Disable image watermark for DJI M3E, M3T, and Matrice 300 RTK.
  • Download plans from Mission Planner with any Pix4D account.
Versions 1.0.1
1.0.1 June 5th, 2023 Bug fixes, Improvements
  • Display a warning if no activity is detected on the drone storage during the mission.
  • Fixed mission not uploaded to the drone due to too many waypoints with DJI M300RTK.
  • Display an error if the drone storage is not initialized successfully.
  • Fixed a crash when sending all the logs from the device.
  • Fixed missing manual images button in asset types.
  • Display geofence errors on the mission checklist.
  • Fixed some missing re-computation of the mission.
Known issues:
  • DJI M300RTK, M3E & M3T drone models require takeoff first with DJI Pilot 2 due to a remote ID error (only for US territory).
Versions 1.0.0
1.0.0 May 3rd, 2023 Initial Release
Meet PIX4Dcapture Pro: the drone flight planning app for aerial data acquisition for 2D and 3D mapping and modeling. With its autonomous missions, this easy-to-use solution is a scalable product with professional outputs, including RTK compatibility. Suitable for every industry and powered by the photogrammetry market leaders Pix4D, this is the solution to set you apart as data collection is made easy.
Features highlights:
  • Create missions from the mobile app or plan missions using the desktop and cloud-based platform PIX4Dcloud with its Mission Planner tool.
  • Offline maps - plan missions in advance and download basemaps to have a visual reference when flying offline in the field.
  • Terrain awareness - the drone follows the terrain to enable optimal processing for the best possible results.
  • Achieve centimeter accuracy with RTK drone support.
Note: Offline maps must be downloaded to enable the Terrain awareness feature.
Workflow:
  • Create a mission or plan on a cloud based platform with PIX4Dcloud’s Mission Planner tool.**
  • Fly your drone!.
  • Upload and analyze your data on the PIX4Dcloud platform or any desktop software by Pix4D.
Note: To access Mission Planner, a PIX4Dcloud license is required. A free 15-day trial is available.
0 out of 0 found this helpful
