Error e0013: Cannot import image location file - PIX4Dmapper
This error appears when PIX4Dmapper cannot import the image location file. This article explains the solution to this error.
Solution
  • Verify that the extension of the images is adequate.
    • Add the .jpg extension in the image names.
  • If an image geolocation file is imported, check that the file structure is correct
    • Additional information regarding the input files can be found in the Input Files article.
0 out of 0 found this helpful
