Disabled DJI Agras boundary mission - PIX4Dfields
This article explains the limitations when exporting a shapefile as a boundary mission for the DJI Agras T-series. The error below is shown "Shapefile export can not be used with this distribution of rates" .
Zone inside zone
It is impossible to export a rate zone that is completely inside another zone as a shapefile for boundary missions.
In this case, the best solution is to export as DJI VRA mission.
Complex prescriptions
Spot spraying application maps are also not compatible with boundary mission exports.
Holes in Boundary
When creating the Operation, a boundary has to be selected in Step 2.
If this boundary contains holes, it will prevent PIX4Dfields from exporting the prescription grid as a shapefile for boundary missions. Holes are represented by a solid pink color.
To solve this,
- Choose the DJI VRA mission instead, if possible.
- Remove the hole from the boundary. In the following example, the central pivot was marked as a hole.
- Double-click on the boundary layer.
- Click the Edit icon.
- Double-click on the hole.
- Click Delete selected item.
- Click Accept.
- Create an Obstacle instead.
