Mission checklist - PIX4Dcapture Pro
The Mission checklist displays a checklist that has to be validated before the drone can start or resume a mission. The items on the checklist can have several statuses:
             ?    Unknown
            loader.png  In progress
             PIX4Dcapture_Pro_Mission_Checklist_Complete.png  Success
             PIX4Dcapture_Pro_Mission_Checklist_Pending.png Warning
             PIX4Dcapture_Pro_Mission_Checklist_Error.png  Failed
Depending on the item on the checklist, a failure can have different causes and different solutions:
Drone connection
  • The App is not connected to the drone through Wi-Fi.
Solutions:
  • Check that the device is connected to the remote controller
  • Check that the remote controller is turned on
  • Restart the App and the drone if you don't find the problem
Drone GPS satellites
  • The drone is connected to less than 6 GPS satellites.
Solution:
  • Wait a few seconds.
  • If possible, take off manually. The drone will detect more satellites if it is above the surrounding obstacles such as buildings.
Drone SD Storage
  • The camera storage reported an error.
Solution:
  • Please try another card or try reformatting the card.
  • Not enough space on camera storage for the estimated number of images for the mission.
Solution:
  • Please clear the space or try another card.
Drone to grid distance
  • The drone is too far away from the grid (more than 2000m).
Solution:
  • Bring the drone close to the grid. It has to be less than 2000m away from the center of the grid.
Drone armed (only for DJI drones)
  • Motors are engaged while drone is not flying.
Solution:
  • Turn motors off or take off manually before starting mission.
Drone battery level
  • The drone battery level is not sufficient (Drone battery level <= Min battery level).
Solution:
  • Verify that the drone's battery is charged (at least at the selected Minimum Battery Level).
  • Low drone battery level (30% >= Drone battery level > Min battery level).
  • Multiple batteries are required.
Solution:
Camera ready
  • Couldn't connect to the drone's camera or couldn't set the appropriate photo mode.
Solution:
  • Restart the drone and Pix4Dcapture Pro.
Flight mode (only for DJI drones)
  • The flight mode switch is not in the correct position.
Solution:
  • Flip the flight mode position to the correct position and wait a few seconds.
Mission upload
  • The mission has not been uploaded to the drone or was rejected by the drone.
Solution:
  • Wait. There may be other takeoff items which must pass before the mission can upload, or it may take a while for a long mission to be generated and uploaded.
  • Make sure the connection with the drone is strong.
  • Restart your drone and start again.
Controller battery level
  • Low Remote Controller Battery Level (Controller battery level <= 20%)
Solution:
  • Verify that the remote controller`s battery is charged (at least at 20%)
  • Low Remote Controller Battery Level (30% >= Controller battery level > 20%)
Solution:
  • Verify that the remote controller`s battery is charged (> 30%)
RTK connection (only for RTK drones)
  • No RTK status
Solution:
  • Ensure RTK status is fixed or disable RTK positioning.
Drone calibration
  • The drone is not calibrated.
Solution:
  • Please calibrate the drone in the drone vendor app, then try again.
Homepoint is set
  • The drone is not connected to enough GPS satellites to retrieve its position.
Solution:
  • Verify that the Drone GPS satellites check is validated.
Geofence
  • The mission is outside the geofence.
Solution:
  • Please change the geofence parameters in the drone vendor app, then try again.
Camera found in database
  • The camera is not recognized as a supported one.
Solution:
  • Ensure that a supported camera model is connected to the drone.
0 out of 0 found this helpful
