Error description: e9027 The coordinate system in the file is not valid. The output coordinate system must be a projection or arbitrary coordinate system. This article highlights a few of the most common solutions to aid the invalid coordinate system issue.
- Projected coordinate system. For more information, Projected coordinate system.
- Arbitrary coordinate system.
- Check the prj file structure in the following article How to obtain or create a .prj coordinate system syntax file.
- Download the prj file from the database: https://epsg.io/.
