PIX4Dcatch app appearance
PIX4Dcatch automatically matches the iOS device’s Light or Dark appearance to optimize visibility, contrast, and interface elements for bright outdoor or low-light conditions.
PIX4Dcatch automatically adapts its interface to match the Appearance selected on the iOS device. This allows the application to be optimized for both bright outdoor conditions and low-light environments.
Requirements
  • Available only on iPhone devices.
  • The appearance is controlled through ther iOS settings iOS Settings, not within PIX4Dcatch.
Supported Appearances
PIX4Dcatch supports the two iOS appearance modes:
  • Light Appearance: Optimized for bright outdoor conditions.
  • Dark Appearance: Optimized for low-light or nighttime environments.
             Display settings Display settings
How to Change Appearance on iOS
  1. Open Settings on the iPhone.
  2. Tap Display & Brightness.
Under Appearance, select Light or Dark.
Note: There is no need to adjust brightness or other display parameters to affect the appearance of PIX4Dcatch.
How it works in PIX4Dcatch
PIX4Dcatch adapts its interface according to the appearance selected in the iOS Display & Brightness settings. The following interface elements are adjusted to improve visibility and usability:
  • Enlarged RTK status card
  • Enhanced touch responsiveness
  • Increased contrast for on-screen tools
  • Improved visibility of the RTK connection status panel
  • Updated wireframe colors for better differentiation
  • Enhanced mesh contrast for improved clarity
  • Enhanced visibility of the alert messages
Tip: In bright outdoor conditions, switch to Light mode.
Dark mode
        dark mode              dark mode
Light mode
         light mode              light mode
