English
  • 検索欄が空のため、提案はありません。
PIX4Dcloudにおける一人称視点のカメラ操作
The First person camera control mode brings improvements to the visualization and navigation of some specific projects, such as indoor projects or those where the space is narrow or delimited by walls, immersing the character in the scene.
ライセンス:この記事はすべての PIX4Dcloud ライセンスに適用されます。
Roles: Only Owners, Managers, Editors, and Readers can access the first person contril within a datasets in PIX4Dcloud.
Advantages of the First person camera control
The First person mode allows one to navigate the space as if the character was walking inside the reconstructed environment and observing it from its position.
It provides a simplified and more intuitive way to navigate indoor spaces, removing interference from surrounding elements such as built and trench walls. When changing the point of view (hold the right mouse button and drag the mouse), the position of the character remains unchanged but the character starts to rotate around its position.
This mode is recommended for:
  • Trenches
  • Tunnels
  • Indoor spaces
Example: 一人称視点でのナビゲーション。屋内での使用におすすめです。
The Focused mode allows one to navigate the space as if it was a satellite flying around a fixed point instead.
When changing the point of view (hold the right mouse button and drag the mouse), the position of the character changes, rotating around the clicked point. When using this camera control with indoor spaces, some surrounding obstacles can interfere with the view.
Example: Navigation flying around the object, not recommended for indoor spaces
Note: Once the Camera control option is defined, this camera control mode will persist, i.e. it will be saved the next time the project is opened by the owner or through a sharing link by collaborators.
How to view a project in the first person
To use the First person view:
  1. Open a project in PIX4Dcloud.
  2. Select the 3D view.
  3. Open the Viewer settings, by clicking settings.jpg.
  4. Next to Camera control、選択 First person.
The project can now be navigated as in the first person.
