タイポイント誤差はどのように定義されるのか - 平均、標準偏差、RMS?
The following errors for the Ground Control Points (GCPs) and Checkpoints (CPs) in photogrammetry project are calculated:
- Mean: The average error in each direction (X,Y,Z).
- Sigma: The standard deviation of the error in each direction (X,Y,Z).
- RMS: The Root Mean Square error in each direction (X,Y,Z).
In order to calculate the values, tie points (GCPs and CPs) need to have measured coordinates that are compared with their calculated position. To measure the coordinates of points, typically total stations and RTK GNSS receivers are used.
Mean
For a given direction (X,Y or Z) it is defined as: Mean = μ = Σ(ei)/N
Where ei is the error of each point for the given direction.
N: The number of tie points.
The Mean Z error helps to recognize systematic errors due to bad GCP acquisition.
Sigma
Sigma = σ = sqrt(Σ(ei - μ)^2)/N)
μ:指定された方向における平均誤差
N:GCPの数
Assuming the error is Gaussian, the Sigma error gives confidence intervals around the Mean error:
- 68.2% of the points of the project will have an error of +-σ
- 95.4% of the points of the project will have an error of +-2σ
- 99.6% of the points of the project will have an error of +-3σ
RMS
RMS = sqrt(Σ(ei^2)/N)
N: The number of GCPs
The RMS error will take into account the systematic error. If Mean error=0, the RMS error will be equal to the Sigma Z error. The comparison of the RMS error and Sigma error indicates a systematic error.
Of the 3 indicators, the RMS Error is the most representative of the error in the project since it takes into account both the mean error and the variance.
