English
  • 検索欄が空のため、提案はありません。
搭載GPSがプロジェクトの精度に与える影響は?
Normally, the GPS of a drone is not very accurate.
The inaccuracy of the GPS may lead to large errors in 3D position, orientation, and scale, as seen below. Therefore, it is strongly recommended to have at least 50% of georeferenced images for an acceptable approximation.
Enough geotags (more than 50%).
Not enough geotags (less than 50%): resulting in wrong orientation and scale of the reconstruction.
Figure 1. How the number of georeferenced images affects the reconstruction of the model.
When there are sufficient GPS positions taken in a grid pattern, Pix4D averages the GPS positions, resulting in a very good approximation of the scale and 3D orientation of the model. However, the optimized position may be shifted 10 to 20 meters due to the atmospheric conditions when the GPS data was acquired. Ground control points (GCPs) have to be used to increase the absolute accuracy of the project.
Tip: Pix4Dmapper takes into account the error of the images' position that is set as Accuracy ( Horz and Vert). For more information: Menu Project > Image Properties Editor... > Images Table.
1-3 meters inaccuracy due to the satellite distance and receiver errors. This error is reduced to centimeters when averaging over a large number of georeferenced images.
10-20 meters global shift of the coordinates due to atmospheric conditions. This error cannot be reduced or detected by averaging the georeferenced images. It is related to the GPS accuracy.
Figure 2. GPS error.
