PIX4Dengine Server first processing
PIX4Dengine 移行を強く推奨します。最新のドキュメントをご覧になるには、PIX4Dengine SDKのページをご覧ください。
- An installed version of PIX4Dengine. See instructions to install PIX4Dmapper on Windows and on Linux.
- Imagery to process. Example projects are available for download.
Other Notes:
- If you are having issues with the command line not recognizing directories or file paths, try enclosing the parameters in quotes like so: "<path_to_project_images>", this will allow most command line functions to process inputs with spaces in them.
- In order to use "pix4dmapper" as a system command, you will need to add the PIX4Dmapper application binary to your system path. If you do not wish to add PIX4Dmapper to your system path, you may replace "pix4dmapper" in the following examples with "C:\Program Files\Pix4Dmapper\pix4dmapper.exe" or the equivalent install location.
1. Creating a project using the default methods.
The following command creates a new project (-n) without launching the GUI (-c) using images from the image directory.
pix4dmapper -c -n --image-dir <path_to_project_images> <path_to_desired_project_directory/projectname.p4d>
This command should cause a command console or terminal console to create a .p4d file and project file structure in the folder indicated by <path to desired project directory>
2. Creating a project using a template
pix4dmapper -c -n --image-dir <path_to_project_images> --template <template_arg> <path_to desired_project_directory/projectname.p4d>
Template <arg> can be:
<template_name>: Use --template-list to display the list of pre-defined templates.
<template_file>: Path to a custom template .tmpl file. The custom template file can be generated either by using the user interface or by manually creating the file: How to create a Processing Options Template .tmpl File.
pix4dmapper -r -c <path_to_desired_project_directory/projectname.p4d> pix4dmapper -i -c <path_to_desired_project_directory/projectname.p4d>pix4dmapper -d -c <path_to_desired_project_directory/projectname.p4d>pix4dmapper -o -c <path_to_desired_project_directory/projectname.p4d>pix4dmapper -i -d -c <path_to_desired_project_directory/projectname.p4d> pix4dmapper -i -o -c <path_to_desired_project_directory/projectname.p4d>
For a full listing of commands, use pix4dmapper -h or see this article: How to use the command line.
Look into more advanced features of the command line here: How to use the command line
Check out how to install PIX4Dengine Server on AWS EC2: How to use PIX4Dmapper on the Cloud with Amazon AWS EC2 Services
