[2024] 技術リリースノート -4
注:この記事には、PIX4Dcloud およびPIX4Dcloud (旧PIX4Dcloud )のリリース更新情報が含まれています。
December 16th, 2024 - Support for new geoids, Austrian and New Zealand
新機能:
- New Geoid models supported:
- Austria: “Austrian Geoid 2008 | GHA” for EPSG:5778
- New Zealand:
- EPSG:5759, “NZVD2016 | Auckland 1946”
- EPSG:5760, “NZVD2016 | Bluff 1955”
- EPSG:4458, “NZVD2016 | Dunedin-Bluff 1960”
- EPSG:5761, “NZVD2016 | Dunedin 1958”
- EPSG:5762, “NZVD2016 | Gisborne 1926”
- EPSG:5763, “NZVD2016 | Lyttelton 1937”
- EPSG:5764, “NZVD2016 | Moturiki 1953”
- EPSG:5765, “NZVD2016 | Napier 1962”
- EPSG:5766, “NZVD2016 | Nelson 1955”
- EPSG:5767, “NZVD2016 | One Tree Point 1964”
- EPSG:5772, “NZVD2016 | Stewart Island 1977”
- EPSG:5769, “NZVD2016 | Taranaki 1970”
- EPSG:5770, “NZVD2016 | Wellington 1953”
変更点:
- Camera support:
- Changed DJI ZH20T, DJI ZH20T, DJI FC6310R, DJI FC6540, and DJI Mavic 2 Enterprise Advanced default vertical coordinate reference system to ellipsoidal height
改善点:
- Improved readability and wording in dataset creation wizard
Bug fixes:
- Compare mode:
- Fixed the issue where the compare mode always displayed the second dataset on both sides.
- Fixed the issue where the compare mode did not display the expected outputs.
- Fixed the issue where the web UI 2D editor sometimes failed to display the corresponding level of detail of the DSM and orthomosaic when zoomed in.
- Fixed the issue where the web UI sometimes took too long to display annotations
- Fixed the issue where the 3D textured mesh generated by PIX4Dcloud could not be opened in some third-party applications.
- Fixed the issue where the web UI sometimes failed to save annotations.
- Fixed the issue where the inspection matches were loading unnecessarily in the background.
- Fixed the issue where the annotation export incorrectly formatted the contents of the CSV.
- Fixed the issue where the site localization coordinate reference system sometimes was not used for PIX4Dcatch datasets.
- Fixed the issue where the PDF quality report sometimes did not include the dataset’s processing options.
- Fixed the issue where processing sometimes failed when AutoGCP did not find enough targets in enough images.
- Fixed the issue where the web UI 2D editor sometimes displayed the DSM with the wong color and an empty histogram.
- Fixed the issue where the web UI 2D editor sometimes did not display the entire DSM or orthomosaic.
- Fixed the issue where the DSM and orthomosaic borders did not align with each other in the web UI 2D editor
ご注意:プロジェクトを開始する前に、PIX4Dcloudのベストプラクティスと機能に関するガイドを必ずご確認ください。
October 11th, 2024 - Improvements
改善点
- Projects uploaded from PIX4Dmatic can use the embedded view.
変更点
- The filling color is the same as the border color in polygon and volume annotations.
- Open action for folders from the three dots has been removed.
不具合の修正
- Fixed the issue where the naming and order of the overlays were not kept.
- Fixed the issue of showing the letters “COG” in the layers hierarchy when an orthomosaic or a DSM was uploaded from PIX4Dmatic.
- Fixed the issue where the output file format shown in the download section was not correct.
September 18th, 2024 - Improvements
改善点
- The project wizard notifies about missing images before processing the dataset.
- Switcher to go from map to satellite and vice versa and zoom controls in the map where images are displayed.
- The Autotag layer can be moved up and down in the hierarchy.
- ESRI CRS are supported in PIX4Dcloud as an output coordinate system and can be selected
- Quality Report now includes the initial coordinates of the GCPs and the computed ones of the MTPs
- The processing wizard informs that DSM is needed to use the virtual inspector, and there is a warning in the cases where there is no DSM
変更点
- The Autotag label that used to be displayed on the right corner of the viewer is not displayed any more.
- The extensions prj / tfw are now included in the orthomosaic and DSM download from the Web user interface.
不具合の修正
- Fixed the issue of having a duplicated 3D mesh layer.
- The Black circle around orthomosaic and DSM is no longer there when uploading to the cloud via the Share to Cloud feature using the latest PIX4Dmatic release.
- Fixed the issue of not being able to download the opaque orthomosaic.
- Fixed the issue of the email not being sent when the AutoGCP feature fails.
- Fixed the issue where the background color could not be changed on the 3D view.
August 28th, 2024 - Visualization of Autotags in PIX4DCloud
What's new
- The Autotags used in the computation of projects uploaded from PIX4Dcatch are now displayed in the PIX4Dcloud user interface (both in 2D and 3D).
改善点
- The resolution of the 3D textured mesh’s texture has been increased from 8192x8192 to 16384x16384.
- Mission Planner supports mission planning in imperial units.
不具合の修正
- Fixed the issue with the virtual inspector not working when the 3DMesh was not selected as output.
August 15th, 2024 - Images and GCPs are displayed on a map before processing
What's new
改善点
- Added support for the following camera models and changed camera model shutter type from global to rolling:
- DJI Air 2S 19.9-megapixel RGB image with 8.4 mm focal length.
- DJI MIni 2 9-megapixel RGB image with 4.5 mm focal length.
- DJI Mavic Pro 12-megapixel RGB image with 4.7 mm focal length.
変更点
- The orthomosaic and DSM are exported in Cloud Optimized GeoTIFF format when the dataset was created with PIX4Dcloud’s user interface.
- The background map provider is now MapTiler.
- Images without geolocation must be deleted before processing.
不具合の修正
- Fixed the issue of sometimes not being able to replace the CSV file containing GCPs in the AutoGCP feature.
- Fixed the issue of some point clouds processed with PIX4Dmapper were not displayed.
- Fixed the issue of an inspection annotation marker placed at the wrong position in the annotations report image for portrait images.
July 17th, 2024 - New processing wizard
What's new
- New processing wizard including:
- New processing pipeline for oblique flights.
- New processing pipeline for flights over flat areas (e.g. crop fields, airports…).
- Output selection.
改善点
- Web user interface no longer displays 2D outputs, including orthomosaic, DSM, and NDVI with interpolated pixels.
- All images with no geolocation can be deleted at once.
- Mission Planner maintains the current map zoom level when creating a new mission.
- Streamlined rendering of Map view dashboard with a large number of projects.
変更点
- Download to Mapper desktop is no longer available for datasets created with the PIX4Dcloud’s user interface.
- Color of some elements has been changed in Mission Planner to improve usability and be consistent with PIX4Dcapture Pro.
Bugs
- For datasets uploaded from PIX4Dcatch:
- Fixed issue when 3D textured mesh generation could sometimes take a very long time to process.
- Fixed the issue when 2D annotations were sometimes not displayed.
- Fixed the issue of zoom changing constantly in the Map View when many projects were displayed.
- Fixed the issue of DXF files not being displayed when the bounding box is very big.
- Fixed the issue where reconstructions were at the wrong absolute elevation when the dataset did not include GCPs because the centimeter-grade RTK geotags' elevations were considered to be relative to geoid model EGM96 instead of the ellipsoid with the following cameras:
- DJI Mavic 2 Enterprise Advanced's 48-megapixel RGB image with 4.5 mm focal length.
- DJI Mavic 3 Multispectral 20.8-megapixel RGB image with 12.3 mm focal length.
June 26th, 2024 - Map view
What's new
- A new Map view dashboard to display the geographic location of the projects and sites.
改善点
- Images without geolocation are highlighted after they are imported.
June 19th, 2024 - Back-face culling for 3D mesh
What's new
- 3D textured mesh back-face culling to improve the visualization of indoor projects.
改善点
- For projects processed with the new 3D maps pipeline or projects uploaded from PIX4Dcatch for processing:
- New geoid models:
- Singapore SGeoid09 for EPSG:6916 “SHD height”.
- Czech Republic CR-2005 for EPSG:8357 “Baltic 1957 height”.
- Portugal GeodPT08 for EPSG:5780 “Cascais height”.
- Corsica RAC23 for EPSG:5721 “NGF-IGN78 height”.
- Extent of EPSG:5713 “CGVD28 height” increased to cover Newfoundland, Canada
- Updated model files for Danish geoid model DVR90.
- Faster processing time for calibration for larger projects.
- Faster processing time for 3D textured meshes.
- New geoid models:
変更点
- The new 3D maps pipeline produces LAZ as default format for the point cloud instead of LAS.
- The outputs produced with the new 3D maps pipeline include the name of the project or the site when they are downloaded.
Bugs
- Fixed the issue of the new 3D maps processing pipeline failing to generate a quality report when the images did not have any XMP tags.
- Fixed the issue of the new 3D maps processing pipeline failing during point cloud densification of especially large datasets.
- Fixed the issue of processing failing when projects uploaded from PIX4Dcatch are missing depth data.
- Fixed the issue of having the wrong icon for annotation groups.
- Fixed the issue of the quality report sometimes not containing the calibration and reoptimization settings.
- Fixed the issue of the change capture date of dataset not working.
- Fixed the issue of third-party applications not being able to display the 3D textured mesh generated with the new 3D maps pipeline.
- Fixed the issue of processing failing when projects uploaded from PIX4Dcatch include corrupted confidence maps or depth maps.
April 30th, 2024 - Improvements
改善点
- Choose the unit of measurement for volume comparison CSV with the unit of measurement switcher in the web UI.
- PIX4Dcloud tutorial videos have been updated.
変更点
- Measurements for relatively short distances or small areas are displayed in decimal feet instead of decimal inches.
- An error message is shown if DXF cannot be displayed in either the 2D or 3D viewer.
Bugs
- Ground control point targets are consistently detected when the dataset's unit of measurement is feet and the images’ geotags are meter-grade.
- EGM96 is not applied by default for images’ vertical coordinate systems.
- Processing finishes successfully when generating DSMs and orthomosaics that, due to their size or shape, cover an especially large geographic area.
- The DXF is not shifted when using the take screenshot feature.
- PIX4Dcloud did not display an error message when an account activation email was sent successfully.
April 8th, 2024 - Project coordinate system manual definition
What's new
- It is possible to manually set a project coordinate system for projects without imported outputs.
改善点
- The exported DXF keeps the annotations with their original colors.
- Fisheye cameras are supported in the new 3D maps processing pipeline.
March 27th, 2024 - SHP export enhancements
改善点
- SHP export enhancements.
- The coordinate reference system picker supports WKT files, including site localization files created with PIX4Dcatch, when using the new image processing pipeline.
- Auto top-up is available in PIX4Dcloud's user interface.
変更点
- Polygon's color setting defines the perimeter color instead of the fill color.
- SHP export is not available for share links.
不具合の修正
- Profile View axes are now correct.
- Custom base surface altitude is now used in the volume comparison feature.
March 5th, 2024 - Credits auto top-up feature.
改善点
- Projects processed from PIX4Dcatch include the project name in the output files.
- Overlays include a button to download the files.
- Overlays include a focus-on button to center the view on the overlay.
- [Credits] The Auto top-up option is now accessible after the second purchase from the user account.
変更点
- DXF export is not available for share links.
- 新着 button design includes access to the New folder function.
January 22nd, 2024 - DXF improvements
改善点
- DXF overlay enhancements to support bigger files and larger areas.
- Coordinate reference system search enhancements, resulting in an improved user experience.
- Best practices article can now be accessed from the user menu.
変更点
- Input images and point clouds are now available for download during the PIX4Dcloud dataset retention period.
